Can I lose the EGR ??
Car: 87 Iroc Z28
Engine: 355 TPI
I hear people talking about how they took off the EGR and blocked off the openings. What does this all effect and will it help performance? If so what else do I have to do other than just taking it off and blocking the hole ???
As a note, Im not really worried about emissions. Don't ask.
Car: Sexy
Engine: Stock
Transmission: Slipping
If you take it off and block the hole, you'll get a constant SES light and your engine may tend to knock.
But that didn't stop me.
I edited the chip to make up for both of these things.
I edited the chip to make up for both of these things. Thread Starter
Car: 87 Iroc Z28
Engine: 355 TPI
ok, I can edit my chip too as soon as I get going on the chip burning (soon).
But I guess my real question is, what do you gain from doing this? any HP, air flow, ..... I just want to know what the reasoning behind it would be?
Car: Sexy
Engine: Stock
I think any gain would be so small it's not worth it. It lets more clean intake charge into the cylinder, but it also raises combustion temperature. As a result, you have to set your timing (compression ratio, etc whatever) down so you don't knock.
The reason I disabled mine is because it was stuck open and I didn't have the 80 or so bucks to replace it. I shot it with 125 PSI from my compressor and unplugged it.
Car: 87 Iroc Z28
Engine: 355 TPI
So basicaly you sayin If it aint broke dont try to fix it. lol I guess Ill just leave it then, seems to work fine. Thanks
Removing the EGR (or abandoning it in place) on a stock manifold doesn't improve anything, and may actually decrease your performance. Check out GM Tech's article at www.sethirdgen.org for the details.
There is no improvement in air flow, since you don't change the intact passages at all. And beyond the annoying little yellow "friend" that will constantly stare at you from the dash, the heads will tend to run hotter and cause preignition and timing retard, meaning lower power and lower fuel economy.
HoosierinWA
Oct 7, 2015 10:15 AM
