I feel so pissed off right now!!
Old May 18, 2002 | 11:34 PM
FatOne's Avatar
85 Z with 350 carb setup. Had old 305 TPI. Got car back from the shop yesterday. Today I checked my oil. Guess what barely any oil was on the dip stick. How can I tell if there no oil or if the dip stick is to short? Man I'm pissed off. Also very strong gas smell comeing from car. Don't know if its the black can or what. I see no leaks what so ever. Seems when I put my hand over carb little mist from it. Is this normal? About the oil I drove this car for almost 30 miles to home. I would think that if there wasn't any or a little oil in the eng. Something bad would happen. No heat problems or nothing. Just a rough idel. HELP ME PLEASE!
Old May 18, 2002 | 11:39 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Only way I know of is to change the oil and see how much comes out.
Old May 19, 2002 | 08:20 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
then add 5 quarts....check it and mark your dipstick...
Old May 19, 2002 | 11:22 AM
MdFormula350's Avatar
as long as there was some oil on the dipstick i am sure u will be ok, just add some oil or if the oil looked dirty change it. add around five quarts depending on oil filter size, and always check the oil when the motor has been turned off for at least 15 minutes to let the oil drip back down into the pan.
as for the gas smell i am not to sure how carbs work, all i can say is to check all ur fuel lines, gas tank, gas filter, gas cap...
Old May 19, 2002 | 02:43 PM
FatOne's Avatar
I'm going to check oil with a coat hanger first. Then add some oil if it is needed. I'll also call that guys shop and ask him what the F%^k is going on. I have check all fuel lines, tank, pump, and the filter in the can. I saw nothing out of the ordinary. I hope some one knows out there.
Old May 19, 2002 | 03:59 PM
MrsLottaBallsCamaro's Avatar
Yeah, if there was some oil on the dipstick, you shouldn't have messed anything up. I'd still be pissed off at them for not filling the oil up though.
Old May 19, 2002 | 08:54 PM
camaro6spd's Avatar
...my car burns oill...BIG TIME i have gone for a while with no oil on the dip stick but there was good oil PSI...so if you did not have abnormaly low oil PSI then i would say you are fine.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
