Throttle Bodey
Old May 20, 2002 | 11:16 AM
Agent-Z28's Avatar
Throttle Bodey
Does anyone know how many Millimeters the stock throttle body is on a 85 Camaro 305 TPI.
Old May 20, 2002 | 11:44 AM
Blackened's Avatar
Old May 21, 2002 | 08:25 AM
Vader's Avatar
Re: Throttle Bodey
Its the same size on a 305 that it is on an L98, LT1, and RamJet 502. The "502" makes over 500HP with the 48mm TB, so don't start thinking that it is a restriction to power....
What can be even more confusing is that the NASCAR and Winston Cup 358 CID engines are making over 700 HP with only four 7/8" diameter holes in the restrictor plates - less free area than a double 48mnm throttle bore by a big margin.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Giocio
Oct 1, 2015 12:20 PM
