Weight Of A 305???
Old May 27, 2002 | 11:30 AM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
Weight Of A 305???
how much exactly does a 305 weigh? does anyone know?
Old May 27, 2002 | 12:01 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
When I took my 1981 305 block in to the shop, my machinist estimated the block to weighing about 110 lbs. This is just the bare block.
A friend has a 283 block that is bored .040 over, and weighs more than my 305, I'm guessing closer to 130-135 lbs.
The older iron blocks up until the 70's were heavier castings, I believe.
EDIT-- I changed the wording slightly in order to avoid the idea that I also have a 283 block, which I do not.
Old May 27, 2002 | 12:40 PM
uk89camaro's Avatar
damn iron heads weight about 44lbs each!! The inlet manifold can't be far behind that!
Would like to know if anyone can tell the entire weight inc. ancill.
Old May 27, 2002 | 11:23 PM
R.O.B.'s Avatar
According to www.241computers.com/ford/eweight.html , it weights about 575lbs.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
