can't get steering wheel back on
Old May 30, 2002 | 04:09 PM
84berlinettaV6's Avatar
The lock plate remover just bends the shaft lock(metal piece with lobes)and it cracked the plastic cover. Maybe I just didn't put it back in the correct order. I took everything out on top of the spring. Does anyone have a good picture? Also my car is a Berlinetta so I think it might be different because the turn signal switch is different.
Old May 30, 2002 | 05:15 PM
i took off three more screws and took off a plastic thingy with wires coming from it. Under that I managed to break some yellow plastic rectangular thing that is about an inch long and has gold metal peices coming from it. What is it? Also, the metal bolt thing moves! It moves in and out almost and inch and it also moves up and down. I still can't get the round metal peice in its groove. Help!!
Old May 30, 2002 | 05:30 PM
ede's Avatar
ede
if i recall the lock plate is indexed, you an't just put it on any way you want
Old May 30, 2002 | 06:00 PM
You're right. It is indexed. I feel like a moron. That fixes most of my problem, but the bolt that holds everything together has a lot of play in it. Is it supposed to move in and out an inch? Also what was the thing I broke. It is something electrical....that's all I know. It is hollow and has two peices of copper on either side. Thanks for the help.
Old May 30, 2002 | 06:33 PM
ede's Avatar
ede
i think what you're talking about breaking is for the horn, the spring should remove the play
Old May 31, 2002 | 11:27 AM
Cool. Thanx man.
Old May 31, 2002 | 10:24 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's hard to tell - but it sounds like you are talking about the plastic trim that accepts the signals for your cruise control. The Camaro, Z28, LT, RS, & IROC columns don't have cruise on the steering wheel and this plastic "plate" is not inside those columns.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
