anyone with a 327....please help!
Old May 31, 2002 | 01:53 PM
woody86's Avatar
i have a pre 69 327 with no accessory holes in the heads. i can't find a passenger side alternator bracket for it anywhere........please help!
Old May 31, 2002 | 05:48 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
I'm not sure how the bracket would bolt up, so I'm going to transfer this over to the Tech/General Engine Board.
I'm confident it will get more responses there.
Also, you might try posting an ad in the classifieds as a wanted part.
Old May 31, 2002 | 08:59 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I've got a 327, but found it easier to swap to newer heads than find brackets. Then I was able to use all the stock brackets and the motor looks like the factory 305.
Old Jun 1, 2002 | 07:42 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
This is strange ...I posted a reply yesterday, but it is not here...anyway, Make sure you have the long style waterpump, the bracket mounts to the pump....I got my bracket from a 70ish Caprice...I had no problem finding one at the JY...the power steering was the hard one for me...had to do some fabricating.
If nothing else March has a kit, real expensive, but looks pretty good.
Myself I would browse the JY...you can find what you need to make it work..
