Head cleaning question
Old Jun 1, 2002 | 12:06 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Is it ok to clean a fully assembled aluminum head(l98) with a solvent?
Old Jun 1, 2002 | 09:08 AM
Guest
Guest
Posts: n/a
That wont bother anything but the valve stem seals. The seals might not like it, depending on the solvent. Another thing is if there is carbon buildup and whatnot in the heads, that might not get cleaned out and you'll have debris where you dont want it. I'd suggest disassembling them. Just keep the valves and springs and stuff in order so they go back in the same spots.
Old Jun 1, 2002 | 09:22 AM
Vader's Avatar
PP,
Max beat me to it. What solvent? Regular old Stoddard (basically petroleum naptha) should be safe.
If you're trying to clean the chambers, water-based cleaners and a stiff brush do a good job. If you use a caustic cleaner (like Fantastic, 409, etc.) make sure you rinse thoroughly and spray with a little vinegar/water mix to neutralize any of the caustic that make find its way into recesses and slowly dissolve the aluminum. Of course you should be able to at least disassemble the rockers and *****, and remove spark plugs.
Old Jun 1, 2002 | 06:10 PM
allmotorta's Avatar
hmm, cleaning up the heads, recently purchased 2800 stall, sounds like your up to something....need any help give me a call
Old Jun 1, 2002 | 08:10 PM
I really only want to clean up the head gasket surface. I was thinking carb cleaner but what water based cleaner should I use? The box that they were in had particles of dirt that is loosly on there so should I just rinse it off with water? Im not up to anything, just a rough running TPI.
Old Jun 2, 2002 | 01:37 AM
allmotorta's Avatar
"Im not up to anything, just a rough running TPI". I hear that brotha, have you tried an airfoil yet? It might get you out of the 17's....
MustangBeater20
Oct 29, 2022 09:20 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
