My fan belt keeps coming off, PLZ HELP!
Old Jun 3, 2002 | 10:24 PM
383 Smoka's Avatar
I just went thru 2 fan belts.. It goes to the crank to the water pump to the alternator.... I put a new one on, tighten the bastard right down perfect and it flips itself off... When it comes off, the belt is flips over... Could I have a warped pulley? Has this ever happened to anyone? Its happened twice today.... How do u fix a warped pulley? Thanks alot....
Old Jun 3, 2002 | 10:40 PM
1986redbird's Avatar
you need to check the alignment on the pulleys, sight across the fronts of the pulleys and make sure they are in line with each other. you should be able to see a bent or warped pulley by looking across the fronts on them when the engine is running.
Old Jun 4, 2002 | 04:08 PM
32789RS's Avatar
like 86 redbird says check the alignment of the pulleys, another thing you might want to do is get a set of deep groove pulleys or if it happens at high RPMs you might want to get a reduction pully.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
