Timing question
Old Jun 10, 2002 | 08:46 PM
Patton's Avatar
Timing question
What should the timing be set at for a 88 Camaro with a 350 TPI and automatic tranny?
Old Jun 11, 2002 | 07:53 AM
felo72's Avatar
If you look under the hood you should have a chart telling you what to set the timing at, usually around 6 degrees advanced. But don't forget to disconnect the wire by your air conditioning box. I'm sorry I can't remember the name of the wire, but if you take a look at a Hayes manual, it will show you exactly what to look for.
Old Jun 11, 2002 | 10:57 AM
Vader's Avatar
6° BTC in DRIVE at 650 RPM - EST bypass disconnected. It's all on the VECI label, like felo said.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
