Hesitation Under Load???
Old Jun 11, 2002 | 06:36 AM
chevyo3's Avatar
Car: 87 Camaro Sportscoupe
Engine: LG4
I finally got the car on the road. It sure has power at least when i first started driving her. I used ti be able to floor it ,and the car would take of like a rocket . Know when I floor it it hesitates ,and boggs down. What would cause this? she runs fine as a daily driver ,but when I want to get roudy with it it boggs.Help
Old Jun 11, 2002 | 08:09 AM
felo72's Avatar
I would definately change the fuel filter, they're only a couple of dollars. If that doesn't cure the problem then we will diagnose it further.
Old Jun 11, 2002 | 09:30 PM
chevyo3's Avatar
Engine: LG4
The fuel filter was the trick. Only cost $1.07. I took her out ,and she flies. Now I need a 120mph speedo. I only have a 85mph speedo ,and I have pegged her. What a improvement.Thanks
Next will be the front shocks or struts ,and then brakes. Any suggestions?
Old Jun 12, 2002 | 07:36 AM
felo72's Avatar
If you don't plan on doing the road course I would recommend a good set of KYB struts, and as for brakes, Raybestos from your local auto store. If you want to go one step further, the struts will still be good for any performance, but you could upgrade the brake rotors to Powerstop cross drilled rotors and VGX pads. Always remember though, if you run these rotors, you have to run the VGX pads, those rotors are known to eat up standard pads.
Fanatic1074
Oct 3, 2022 05:57 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
