Plastic Plug in the Radiator!!!!!!????????
Old Jun 12, 2002 | 07:06 PM
Dans91's Avatar
Car: 91 RS
Ok the other day i noticed that my fan was not ingauging, so i bought a fan turn on switch from JET, well i drained the block and also the radiator, before i unscrewed the plug i noticed that it was leaking already, so i unscrewed it. Well come to find out the plug was plastic and had beed strippd from before, How do i fix the problem, can i buy a bigger one that wont strip, or can i use a gasket maker on it, how can i fix it so that i dont have to worry about it leaking any more..
Thanx
Dan
Old Jun 12, 2002 | 09:03 PM
Guest
Guest
Posts: n/a
What plug? Drain plug for the radiator? Theres a plastic insert in there thats replaceable, make sure you get the replacement FIRST if thats what it is, so you dont screw up the tank taking your old one out.
Old Jun 12, 2002 | 11:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Where is this plug located?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
Glowsock
Aug 26, 2015 12:28 AM
Zachattack0925
Aug 12, 2015 09:52 PM
