Dream Motor
Old Jun 18, 2002 | 07:17 PM
Rage13's Avatar
Car: 89 Firebird
Dream Motor
Ok guys/gals, What would be the best way and best parts to build the bigest small block you can make? Looking for a parts list from air cleaner to oil pan, money ammount makes no difference. How would you go about it?
Old Jun 18, 2002 | 07:21 PM
rezinn's Avatar
How much power do you want?
What is the purpose of this car?
Do you have to deal with any smog laws?
Old Jun 18, 2002 | 07:27 PM
Rage13's Avatar
Car: 89 Firebird
Come on now, thats like asking a kid how much candie he wants.
1. I'm looking for as much power as I can get without Nos (don't like the idea of bottled horses).
2. Street/strip car
3. I live in FL, and i hope not because i just riped all that $hit off my 305
Old Jun 18, 2002 | 08:31 PM
lankchevy_350's Avatar
lets see here. deep sump oil pan, .30 over aluminum 350 block, stroker crank, 6 inch aluminum rods, 13 to 1 forged pistons. all felpro gaskets, melling oil pump, holley elctric fuel pump, the new crane ignition( i think its called like m6 or something?) .62 lift cam, hydrolic roller lifters, aluminum edelbrock heads with 2.10 and 1.90 valves, edelbrock airgap aluminum intake. holley 800 double pumper carb, or if u wanna stick with fi holleys new stealth ram. hooker supercomp headers, hmmm what am i missing? oh ya 1.6 roller rockers, and..............well u get the point, i spend way to much time dreaming with my nose in summit and jegs. lol.
kolby
or 10 to 1 pistons and a 8-71 blower and duel holley 650s
Old Jun 19, 2002 | 07:10 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Motown 427 smallblock shortblock w/ AFR 227 heads, miniram, a D-1 SC Procharger, and a custom cam.
Old Jun 19, 2002 | 07:49 AM
Vader's Avatar
DREAM engine?
Si-Al racing case w/ steel sleeves, raised camshaft position, 4 bolt forged splayed main caps;
Dry sump;
Two sets of staged injectors per cylinder;
2.20/1.76 Ti valves;
A '94-'95 flash-ROM PCM with MAP and MAFs;
DIS ignition with four coils;
Titanium con rods and forged Si-Al (not hyper-eut) pistons;
Forged Cr-Mo steel crank;
Priority main oiling;
Cast iron headers;
Single roller (RC-80) timing set;
Hydraulic rollers;
Cr-Mo forged rockers;
Ti push rods;
'O' rings instead of gaskets - better yet, quad rings instead of gaskets;
Static compression of 8.7-9.2:1;
18° heads fit to LT1/4 intake;
Dual 60mm TB;
Dual Garrett T-76 chargers;
All cradled neatly in a C-6 chassis.
Old Jun 19, 2002 | 07:50 AM
ede's Avatar
ede
my dream engine wouldn't be a small block, wouldn't even be a v8 and if you're talking about a dream motor it must run on eletric. thread is locked for lack of relevent tech content
87iroctheo
Dec 4, 2016 11:47 AM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
