#1 piston to TDC
Old Jun 23, 2002 | 04:38 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
#1 piston to TDC
Please help.
My chilton tells me to put the camshaft sprocket timing mark @ 6 o'clock, and the crankshaft sprocket timing mark @ 12'oclock. The pictures that are with these instructions show this same alignment as having the #6piston @TDC. Another picture shows both sprocket timing marks pointing straight up as having the #1 piston @TDC. It has confused me, and gotten me off schedule. I was hoping to be driving it again this week. Can any help me out as to how I set the timing marks to get #1 @TDC???
Thanks a lot,
Brett
Old Jun 23, 2002 | 07:11 PM
ede's Avatar
ede
dot to dot is with #6 firing, both dots straight up is #1 firing. i like ot set it up with both dots together then spin it once till both dots straight up and time it from #1
Old Jun 24, 2002 | 08:57 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
thanks a lot,
That is what everybody seems to be saying. My chilton just had me confused. I am going to go install the new chain as soon as I can find someone that knows how to get the crank sprocket to slide the rest of the way on. It is almost there, am right past the split section of the guide you use to slide the keyway on.
Any suggestions?
Old Jun 24, 2002 | 09:57 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Might want another opinion before you try this, but if I remember right, we slid the old gear on the crank (no key of course) to act as a spacer, then tapped it on. A large socket over the end of the crank gives you something to tap on.
Old Jun 24, 2002 | 10:27 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
good idea. Not sure if I have a socket that big, but I can find something. that will probably work. Thanks
Old Jun 25, 2002 | 08:40 AM
Vader's Avatar
Make sure the Woodruff key is seated correctly, so that one edge is not raised, catching the sprocket as you install it.
You can heat the crank sprocket to about 300°F in an oven to help slide it on with less force. Use a leather welding glove and work quickly, since the sprocket will begin to shrink as soon as it contacts the "cold" crank snout.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
