two pulse vss == manual or electric speedo? (aka, vader, help)
Old Jun 24, 2002 | 11:38 AM
lopoetve's Avatar
Ok. From what I've read, the VSS being out can cause some of the problems I've had, and since I'm throwing a code 24, I'm gonna replace it. Now, the question is... On an 87 Firebird Formula (305 TPI) I have a two-pulse VSS (http://www.jagsthatrun.com/Pages/Spe...eedometer.html)... Does that mean it is mounted on the speedometer, or on the tranny? (Manual tranny). Or, is it's location totally unrelated to its type? What is the part number for the correct vss/cable that I need?
Thanks, all, for any help!
Old Jun 24, 2002 | 12:15 PM
Morley's Avatar
It is mounted to the back of the instrument cluster and points at the speedo head. Don't know on the P/N, can get the P/N on an '85 unit if you want.
From the link you provided.
1. The two-pulse (2000 pulses per mile) square wave (D.C. current or direct current) used on all TBI engines through 1992, all computer-controlled-carbureted engines, and on 1985–1989 TPI engines.
Well wouldn't you know it, I have an extra one in the garage but there isn't a P/N on it.
Also this was for a camaro, don't know if the bird is the same.
Old Jun 24, 2002 | 01:34 PM
lopoetve's Avatar
So it is a mechanical speedometer, with the VSS mounted to the guage. Guess I'll replace the speedometer cable first tranny to cruise control thing, then try the vss.
Old Jun 24, 2002 | 02:03 PM
Momar's Avatar
Actually on the bird, it should be a electronic speedo, at least it is on the t/a's from late 86 and up. It didnt change for the camaro until 90. Your vss should be in the tranny.
Ben
Old Jun 24, 2002 | 02:28 PM
Vader's Avatar
Yes. Check this thread:
https://www.thirdgen.org/techbb2/sho...648#post734648
Old Jun 24, 2002 | 02:31 PM
lopoetve's Avatar
All right! I thought I saw that thread, but I couldn't find it again...
So, how easy is it to replace that bugger?
And which cable do I get??
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
tommy z-28
Oct 6, 2015 10:58 PM
TrevinE
Sep 14, 2015 03:20 PM
Magman
Sep 12, 2015 11:55 PM
