LT4 springs in LO3?
Old Jun 25, 2002 | 04:09 AM
alohamike's Avatar
LT4 springs in LO3?
Will the LT4 springs fit on my stock heads w/o machining? if not, what are good springs for a cam that lift .431/.451
Old Jun 25, 2002 | 07:20 AM
ede's Avatar
ede
stock springs should be ok, l98s. not sure if the other springs will fit or not. you have a spring seat diameter of 1.25" if the lt4 is 1.25 then you're ok
Old Jun 25, 2002 | 12:56 PM
alohamike's Avatar
thanks
ede,
thanks, man. I checked the the LT4's are 1.32". I'm gonna go with the 350/350 springs which are 1.24" and should hold up to the .431/.451 lift.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Dragonsys
Sep 25, 2015 03:51 PM
