383 stroker question...
Old Jun 27, 2002 | 04:28 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Finishing up a kit 383. The cam is a 230/230 .480/.480 regular cam. I thought I would need to go to a small base circle cam. I cleared any parts in the engine that would hit, problem is the cam is opening the intake valve before the exhaust valve is totally closed. I called a shop that built my dad's 383 and he said this is normal. I just want some other opinions on this.
Old Jun 27, 2002 | 05:48 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
What kind of intake are you going to be running and are you adding any power adders like a blower or N2O??
I don't think you want to have any overlap on a car that you are going to be driving on a normal basis. I would think you will be bleeding off too much pressure from the cylinders??
Old Jun 27, 2002 | 05:55 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Even stock cams have a little overlap. That's normal.
Old Jun 27, 2002 | 08:07 PM
Car: 89 IROC-Z
Engine: 383
I stand corrected.
Cam specs and theory is still a topic I need to study up on.
Old Jun 28, 2002 | 09:19 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Thanks guys. By the way it's a torker II single plane manifold.
I'd love to add a 6-71 or a supercharger down the road, but i think my compression will be too high, so probably NOS.
Old Jun 28, 2002 | 10:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, totally normal.
Your car will go faster with a Performer RPM than with that thing you have on it now. It would also run better with a XE274 cam than it will with that older 280H. This is especially true if you add nitrous. That's essentially like dumping liquid oxygen and solid fuel into the motor: it bypasses the intake restrictions, but you still have to get the waste products out somehow. A cam with a bigger exhaust lobe than the intake will make a major improvement over the old single-pattern designs.
Old Jun 28, 2002 | 09:31 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Actually I'm building this for high rpm use so I have no use for a dual plane intake.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
