Need help removing 1/4 pipe plugs from block.
I'm trying to tear it down to finish cleaning it, but the plugs wont budge. They have a 1\4 drive socket. Ive tried the wratchet, but they all keep breaking. Ive looked from a 1/4 drive for my impact, but I cant seem to find one. Is it safe to heat around it with a propane torch? I'm really stuck here. Thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They were installed when the block was still hot. The 1/4 drive stuff won't be strong enough. An impact 1/4 drive "might" work.
An old trick is to get an old head bolt and grind the end down to a 1/4" square. The head bolt is very strong and will allow you to put a 5/8" socket on it.
Another trick is to heat it up with a torch then melt a candle around the threads. The heated wax will soak into the threads and help unseize the plugs.
I've never tried either method but it gives you something to try.
