Knock Knock?!?! WTF?
Old Jun 30, 2002 | 11:17 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Coming home last night was the first time I noticed this noise.
It sounds like I'm running over something, but I'm not. It only occurs when I start to go from a stopped position (i.e. red light or stop sign) w/ a little bit of throttle. It's a little bit worse with the more throttle I use. It sounds like something is hitting the undercarriage or I'm running over a big rock.....??
Any ideas?? It's consistently 2 knocks; one right after the other.....
Old Jun 30, 2002 | 01:18 PM
ede's Avatar
ede
check your trans mount if it's broke, and i bet it is, buy a poly mount from ES, pretty much bullet proof
Old Jun 30, 2002 | 03:12 PM
rezinn's Avatar
Check your trans mount, torque arm bushing, and panhard rod. I had some noise below that was similar and all three of these were broken. You may as well inspect everything down there when it's convenient.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
