fuel pump test?
Old Jul 4, 2002 | 02:21 AM
orod's Avatar
Car: 86 Z-28
fuel pump test?
Not sure if this is true, but can you check a electric fuel pump on a TPI engine from the ECM connector? Been having starting and running problems lately and just changed the spark control modual and now just as hard to start and runs worse. anyone ever use/have a ignition spark tester and where can i get one?
Old Jul 4, 2002 | 11:24 AM
ede's Avatar
ede
i ithnk what you need to do is check fuel preasure at the schrader valve on the fuel rail. even if the fuel pump has power or runs doesn't mean it's building or holding preasure
Old Jul 5, 2002 | 10:44 AM
Vader's Avatar
Orod,
A pressure test is a good idea. If you want to test the pump electrically, you can test it from teh 'G' terminal on the ALDL, but that relies on the pump relay for continutity. It's best to test it at the pump relay socket, so you have a direct circuit to the pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
