main bearings
Old Jul 12, 2002 | 11:53 PM
radiateu2's Avatar
main bearings
on a 305 motor, do the main bearings have anything to do with a low oil pressure problem. I think I found the low oil pressure problem the oil pressure switch was leaking oil on to the transmission. Some one told me the low oil pressure could be from a bad main bearing. Could this be.
Old Jul 13, 2002 | 01:25 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A bad main or rod bearing will have excessive clearance.
When excesive clearance is present, the oil is allowed to leak out at a much greater rate than normal, decreasing oil press to the rest of the eng.
How low is the press at idle and at crusie RPMs?
Did you measure the oil press with a direct reading gauge that's known to be good?
Is it knocking?
The oil leak at the press switch is probably just making a mess.
Old Jul 13, 2002 | 05:07 AM
ede's Avatar
ede
what are you calling low oil preasure? i doubt if bad mains would cause a majot problem, i'd make sure what the oil preasure actually is, use a mechanical gauge screwed into the block. if it's low i'd suspect a failing oil pump, the cam bearings, then mains.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
mfp189
Sep 27, 2015 09:25 AM
