Fuel pressure - is this normal
Old Jul 22, 2002 | 11:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
At idle in park my car reads 43 psi.
In drive and stopped the pressure drops to 39.
At cruise the pressure hangs at 39 but sometimes hits 40.
At roughly 1/2 throttle to WOT the pressure increases to 43.
Is it normal to get only a 4 psi difference in pressure?
I have the L98 auto
Old Jul 22, 2002 | 07:26 PM
BOTTLEDZ28's Avatar
Transmission: A4
what kind of gauge are you running. mine reads 43 at idle and goes to 49 at WOT. thats with an AFPR though. mechanical gauges give the best reading with fuel pressure.
Old Jul 22, 2002 | 07:33 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Fuel pressure should vary directly with manifold vacuum. You should get max pressure at 0 vacuum (WOT, or with vac line disconnected at regulator), lowest pressure during idle/light cruise/decel. If thats not what you are seeing, something is wrong with your regulator or the vacuum line is connected to the wrong source
Old Jul 23, 2002 | 11:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm running the electrical nordskog gauge.
stock regulator
vacuum hose at regulator connected to the plenum
It sounds like everything is working fine. I'm just questioning why my range from idle to WOT is only 4 psi. Could there be a problem I'm not seeing?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
