please explain the numbers and letters on sparkplugs
Old Jul 25, 2002 | 03:01 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I'm looking to get new sparkplugs for my car.
I have ac delco R44LTSM's I want to get plugs with a short thick electrode, perhaps a colder range and that will still work in my vortec heads.
I'm going to be using nitrous soon.
Old Jul 25, 2002 | 05:17 AM
ede's Avatar
ede
the letters have to do with the thread size, reach, tapered or gasket, and i believe overall length. the numbers are the heat range. check the web site of whoevers plug you want to run for me detailed info.
Old Jul 25, 2002 | 08:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, each mfr has a different set of codes...
The AC ones are fairly simple. 1st letter R = resistor; 1st number = thread size (4 = 14mm, nearly all auto plugs are this size); 2nd number = heat range: higher # = hotter; L = long reach; T = tapered seat, no T = washer seat; S = extended nose (ceramic & center electrode protrude 1/16" or so past the shell), no S = standard nose, where the end of the ceramic is even with the shell; no idea what M is.
Other mfrs' schemes are similar but not identical. One step in heat range is a different amount from one to another. For instance, a 3 # step in Champion is about equal to a 2 # step in AC. Other than the heat range, they all have to have the same sort of variations in construction; some (Champion for example) include construction details like C = copper electrode.
Old Jul 25, 2002 | 10:41 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
thats what I was lookin for, thanks guys :rockon:
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
