fuel pump interchange question
Old Jul 27, 2002 | 10:31 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i need to know if a tpi pump is a direct replacement for an in-tank lg4 pump or do i need the whole sender too? thanks
Old Jul 29, 2002 | 08:50 PM
Car: '87 Camaro LT
Engine: 355 L98
btt
Old Jul 30, 2002 | 02:24 AM
GilmourD's Avatar
A TPI pump puts out over 40psi, which would basically turn your QuadraJet into a fuel fountain. IF I remember correctly, my LG4 mechanical pump is putting out between 5 and 6. It's gotta be somewhere around there, cuz my Edelbrock 1406 likes it, and they flood over 6psi.
Old Jul 30, 2002 | 03:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Lg4s do not have an in-tank pump, it is instead a mechanical fuel pump mounted on the lower passenger side of the block and driven via a pushrod which rides on the fuel pump lobe on the cam.
Old Jul 30, 2002 | 07:15 AM
Car: '87 Camaro LT
Engine: 355 L98
LG4s do in fact have an electric in tank pump which is low pressure, I don't know if they all did but my '87 does. I'm converting to fuel injection, hence the reason for switching pumps. I know a guy that converted from TPI to carb and left his stock pump in, well his car caught fire!
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
