Rear Brake Squeel??
Old Jul 29, 2002 | 08:41 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Rear Brake Squeel??
MY GFs '96 Blazer's rear drum brakes squeel when coming to a stop. At least it sounds like it's from the back. What does this usually mean is wrong?
Old Jul 29, 2002 | 01:50 PM
Knight350's Avatar
When was the last time the pads were changed? Probably just the brake pad wear indicator touching the drum...if not, You may want to just pop the wheel off and take a look at what might be touching or streached (springs)... let me know what you find...
Take care
Fredel
Old Jul 29, 2002 | 04:48 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Sometimes a simple build up of brake dust can cause a squeal. Pop the wheel off and use some brake cleaner on that bad boy. Also, have a look for stones that may have become lodged in there.
Si
Old Jul 30, 2002 | 09:23 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Sometimes the drums and pads just get 'glazed' especially if they are organic. Take some 180 grit and sand in a circular pattern on both the drum and the pad (If they are in good shape)
Old Jul 30, 2002 | 10:26 PM
jfox55's Avatar
If it is when you hit the brakes, then it shouldn't be the indicator. They normally go off all the time, then when you hit the break it causes enough pressure to make it stop. In that case I would say it is either glazed , or there is rivit to brake drum contact. If it just making that noise all the time, then it is your brake wear indicators. If it is the indicators, you can always take a screwdriver and bend them back a little, or just pop them off, until payday, so they don't drive you crazy. Just don't forget or you will then hear what rivit to drum sounds like.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
