1984 Q-Jet on a LG4
Old Jul 31, 2002 | 12:43 AM
kev_n_ang_ta's Avatar
Car: 1984 TA, 2001 Monte Carlo SS
Engine: 305 LG4, 3.8 200 HP
1984 Q-Jet on a LG4
This LG4 is all stock and everthing is hooked up. And it seems to be running really rich. Does anyone know how i can fix this and what might be causeing it . and can it be adjusted by drilling out the covers to the adj. screws (like I had to do back in the good old days) I have a 1984 Trans Am WS6 with a LG4 cowl induction.
any help would be greatly appreciated. :hail:
Old Jul 31, 2002 | 04:50 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yes you can drill the plugs out. But the mix is set at the factory and should be correct, while the electronic circuit on the front of the carb should be controlling things as well.
Probably it is time for a rebuild.
Old Jul 31, 2002 | 10:28 AM
If I rebuild it would their be a need to adjust it or will the factory setting stay where they need to be and Im thinking if they stay maybe i should drill them anyway just in case one of these day I do need to adjust them . but I would think that during a rebuild that it would need to be readjusted!
Old Jul 31, 2002 | 12:38 PM
jeffs82z28's Avatar
Before you start drilling and hammering and swearing, and firing dollars at it, I would strongly suggest you buy a year specific factory service manual and follow the diagnostic procedures the factory recommends.
They built it and probably know how to fix it better than most.
But that is just my opinion and I could be wrong.
If you are interested, using the procedures outlined in the manual, you may want to check the dwell of the m/c solenoid, tps adjustment, and even the o2 sensor.
Old Jul 31, 2002 | 04:12 PM
Engine: 305-4v
Jeff's advice sounds good.
For more take your Q to the Carb board and ask Damon, F-Bird'88 and five7kid their opinions. They know QJets pretty well
Old Aug 1, 2002 | 08:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it runs OK at cruise, maybve a little rich but OK, but seems to be black smoke rich at idle, it probably has leaking plugs under the primary jets.
69GTOby
Apr 18, 2016 02:34 PM
Night rider327
Oct 9, 2015 09:25 AM
lanceflame44
Sep 25, 2015 12:28 PM
Night rider327
Sep 25, 2015 04:19 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
