what would cause this??
Old Jul 31, 2002 | 02:20 PM
khellendros's Avatar
As soon as i start my car, it idles fine. Minute i touch the gas... it dies.... I changed the IAC valve... the MAF sensor... and the TPS has the right signal voltages throughtout the course of the acceleration process. I hooked up a diagnostic computer check it gave me code 34. MAF/MAP sensor signal voltage low.... i dont have a MAP sensor.... i just changed the MAF.... got a remanufactored MAF sensor.... Help.... Thanks.
Old Jul 31, 2002 | 03:54 PM
Could my timing be off by 10 Degrees cause this?
Same question as above.
