holley sytemax 2 system
Old Aug 6, 2002 | 04:40 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
350 block
When the heads changed it 87 does the block remain the same?
I am just trying to find out why pistons and crank kits say 1968-1986 i always thought that just the heads changed. and if i rebuild a 350 block that had centerbolt heads will the old style heads bolt to the block? Any help would be very appreciated!!
Old Aug 7, 2002 | 10:16 AM
Vader's Avatar
Head mounting bolt, coolant passage, and dowel hole locations are the same.
During the 1986 model year, the case was changed in the crank area to incorporate a one-piece rear main seal, which is why many manuals and parts listings differentiate between the pre-1986 cases and later ones. From the perspective of the heads, there was no difference until the Gen II engines were introduced in 1993.
If I understand your question, your 1987 and later SBC heads should fit a pre-1986 case without problems. Be aware that there may be some intake and rocker cover mounting issues, however.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Magman
Sep 14, 2015 01:30 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
