tach question
Old Aug 7, 2002 | 11:48 PM
fatass's Avatar
Car: 1986 Sport Coupe
Engine: 2.8l V6
Transmission: 3 speed auto
tach question
this is not for a 3rd gen but maybe you can help me. i just bought the 5 inch autogage tach. from summit racing. it came in the mail today. i was looking at the instructions on how to install it and i understood everything except for the green wire. which goes to a coil or electronic ignition. the distributor i have is this http://store.summitracing.com/global...UM-850001R.jpg and i am not sure how/if you can hook up the gauge to it.
it's a chevy 350 in a 70 chevelle that doesn't have a tach allready
Old Aug 8, 2002 | 06:11 AM
ede's Avatar
ede
you should be able to attach the green wire to one of the wires going into the distributor, that would be your coil wire.
Old Aug 8, 2002 | 08:22 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if he is using that distributor, and the wire he is talking i assume is the signal wire to the tach, he needs to put a female, spade type connector on it, and run it to the distributor next to where the heavy pink (usually) ignition wire goes to the distributor, there is another slot this is where you plug in a tach,
if you don't get it i'll go take a pic of a distributor, use fancy arrows to illustrate
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
