oops hey vader or ede
Old Aug 15, 2002 | 11:47 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
replaceing my trans and spun motor without distributer in. can you supply with the info to reset the timing to #1 tdc?
Old Aug 15, 2002 | 01:10 PM
flyin89's Avatar
I'll answer so if your in a hurry! Hope it helps you.
If you pull the number one plug front driver side,cover the hole with your finger have a friend or use a jump switch bump the starter easily (little at a time until you feel compression trying to BLOW out the cylinder) then continue to turn it in the same direction until your groove on the balancer lines up with the TDC mark on the Timing tab.
Old Aug 15, 2002 | 02:20 PM
ede's Avatar
ede
you really shouldn't ask for someone by name when anyone can supply the info. if you have something you really want directed to someone try the PM feature. after i figured it out it works pretty good for me.
86Firebird86
Dec 26, 2015 07:21 AM
makaveli09
Sep 15, 2015 10:43 AM
89 formula TPI
Sep 8, 2015 08:00 PM
90formulaVortec
Sep 8, 2015 12:42 AM
toyotekk
Sep 6, 2015 02:21 PM
