? about electric fuel pump
Old Aug 25, 2002 | 10:00 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I'm wondering if the symptom I have is a sign of a "soon to go" fuel pump... What happens is when I turn the key on, the pump spools up, and I can start the engine and it'll stay running with no problems. BUT when I shut the engine off, and the pump normally runs for a few seconds, it is now intermittent, not steady. It will shut down completely, as it always has, within a few seconds, but as I said, during that point of the engine shutting off and the pump shutting off, it is now a "stop and go" scene... I haven't had a real chance to mess with it, thought maybe it might be the relay, too. I'd rather change that than the pump Thanks for any replies...
KAM
Old Aug 26, 2002 | 07:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Would seem the oil pressure switch would be the likely cause, but not really a problem/issue to be concerned with, IMO.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
