head size
Old Aug 27, 2002 | 11:52 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
head size
ist it true that the biggest valves being the 2.02 and 1.94s are too big for a street car. a guy at a performance racing shop said that they are to high flowing and are not that good for the street. is that true. to some extent? or is he full of shiznit?
Old Aug 28, 2002 | 12:17 AM
jimmy_mac's Avatar
I say it is bs. Tons of factory heads built for street driving with 20 plus miles per gallon fuel requirements and high vacuum requirements run 1.94 heads. Drive any stock L98 f-body. Very streetable. And really the volume of the runners and size of camshaft used is probably more important for streetablility than the actual valve size. I have 305 HO heads that have been fitted with 2.02 intake valves with the 270HR comp cams camshaft and it gets decent mileage and behaves very well.
And if he is talking about low end torque again the size of the runners probably is more important to look at. Putting 2.02 valves in a set of 160cc heads will probably still be a very torquee set of heads. While putting them is 220cc heads will probably be a higher reving higher horsepower maker.
Old Aug 28, 2002 | 08:14 AM
ede's Avatar
ede
did he mean they were too big physically to fit? good chance they are without changing seats. he may of also meant there would be little gain to be had for the effort and expense.
Old Aug 28, 2002 | 08:38 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
well he did say that i wouldnt noticed much difference except int he high end but he said if its for the street it wont see to much high end anyway. he pretty much told me its a waste. i think he ment waste/effort so i can see that i was just confused.
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
