Error code Remedy
Old Sep 3, 2002 | 10:35 AM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
Error code Remedy
I checked my error codes today, and got the following 3
23-Low temp at Manifold or Throttle Position Error
33-High Voltage (low Vac) at MAP
and
42- Fault at electronic spark timing circut or fault at direct ignition system or fault at fuel cutoff relay circut
what do I do to get rid of them?
Old Sep 3, 2002 | 11:33 AM
ede's Avatar
ede
fix the problem(s) and clear the codes
Old Sep 3, 2002 | 11:58 AM
Red_Demon's Avatar
sorry I should have been specific.. I need to know how to fix the problems, so I can clear the errors..
Old Sep 3, 2002 | 12:00 PM
ede's Avatar
ede
follow the flow down trouble shooting procedure in your manual will locate the problem. or you could just replace parts that are associated with the code, like most people, and hope it takes care of it.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
