Running to hot?
Subscribe
Sep 5, 2002 | 09:51 PM
Sorry it is so long!
I had my 86 TA takin down to the shop for an engine swap. I had the old 305 TPI (LB9) takin out and a new rebuilt 350 put in. I had used my old TPI set up but put in 21lb fuel injectors. For some reason they had it running and my gauge said it was running between 250-260*. he put in a aftermarket gauge because he thought mine was bad (he was right it is off) but it is still running anywhere between 210-230. he replaced the sending unit and tore appart the manifold and check a bunch of stuff but will still continue to figure out what is going wrong. To get to my point i was told by my uncle (original owner since new) that the car ran between 210-220 and i also heard somewhere that a new engine runs hotter anyhow. Is this right? Does my car run normal? Any help would be great.
Reply 0
Sep 6, 2002 | 03:58 AM
That's pretty hot, but by no means hot enough to damage anything. But think about it this way - if the car is running that hot without a lot of stress(just idling or cruising), wait until you start going up a hill or accelerating quickly. It'll overheat for sure. I'm 100% sure that the stock radiator for a 305 is sufficient for a mild 350, as is the dual fan setup, but I don't think you have that. I may be mistaken, but if not it may do you good to look into some better fans, or replace the water pump if it's old. My water pump is hurting a bit, so I bought a stewart one to put in later.
By the way, there is a cooling board now.
Reply 0
Sep 6, 2002 | 11:08 AM
I would think excessive time at 250-260* would start to damage things, but I'm no expert. I get worried when mine has reached 230* before.
Reply 0
Sep 6, 2002 | 05:01 PM
running hott
I talked to the guy again today and he has tried pretty much everything and is thinking it is just normal for my car to do this. From what i have heard new engines will run hotter and if mine was running at 220* before then 230* could just be becuase of the new engine. He has takin it out for a few drives and says he will take it out on monday for an hour drive to see if it is ok.
Reply 0
Sep 6, 2002 | 05:02 PM
Hey mark my car isn't actually running 250-260*, i said my gauge was off and the aftermarket gauge was reading 210-230*.
Reply 0
Sep 6, 2002 | 05:10 PM
He said it is fine until a straight strech of road (flat) and it creeps up to 220-230*. At idle i guess it is at 210*. He's not sure but says that the fans weren't kicking in until 240*.
Reply 0
Sep 6, 2002 | 05:31 PM
Give it a few days and see if it still does it. Mine did pretty much the same thing for 3 days after the swap (about 75 or so miles), and now it won't go over 220.
Reply 0
Sep 6, 2002 | 09:55 PM
flyway190: How hot did your engine get?
Reply 0
Sep 6, 2002 | 11:58 PM
Quote:
When I was breaking it in, I had to shut it down after about 17 minutes because it was at 260+. The next couple of times I left it to idle in the garage (to adjust timing, etc.), and it was in the 240 range. When I was driving it, it would get up to 220-230. After a couple of days it set its operating temperature at 220, and wouldn't go over. This was with about a 180-degree thermostat, 50/50 mix, and a mechanical fan.
Reply 0
Sep 7, 2002 | 12:05 AM
same here with my breakin. Got way too hot way too fast. Itll gradually run cooler as the engine breaks in.
Reply 0
Sep 7, 2002 | 01:27 PM
Do you have an air dam?
Reply 0
Subscribe
