HP numbers
Old Sep 7, 2002 | 09:12 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
HP numbers
ok i am running a 2bolt main 350, bored .30 over the cam specks are 224* duration intake/exhaust and lift is 165*, ported/polished heads, edelbrock preformer intake and edelbrock 600cfm carb. and running 4 degrees after on timing.
Old Sep 7, 2002 | 09:13 PM
rezinn's Avatar
165 degrees of lift? neat. You may want to put the exact type of cam and heads you have and the exhaust.
Old Sep 7, 2002 | 10:20 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I assume you mean .465 inch of lift.
Anywho, somewhere around 330 to 350 hp. That is assuming you have headers and a decent exhaust.
Old Sep 8, 2002 | 02:19 AM
Squeeks83's Avatar
i am putting on flowmaster exhaust, 3 inch, and some 1 and 5/8th's inch headers, i dont know the brand, the cam is a summit cam, and the heads are the stock 350's
those HP numbers, are those at the wheel or crank, because i was told by my friend and guy who built it that it should be making 400 at the crank. and i belive him, ive seen his door slammer he built for drag racing.
Old Sep 8, 2002 | 03:23 AM
Engine: 305-4v
HP at the flywheel.
I don't think that combo will push 400 hp.
Old Sep 9, 2002 | 05:54 PM
Squeeks83's Avatar
then what numbers do you think at the wheels
Old Sep 9, 2002 | 06:01 PM
Engine: 305-4v
Knock 30 hp or so off the DD2000 numbers to get net hp, i.e., flywheel hp accounting for the losses due to the water pump, alternator, etc.
Then subtract 20% from what remains for automatic transmission parasitic loss, or 15% for manual trannies.
So if you are making 350 hp, you will make around 320 net. Then subtract 20% of 330 and you = about 260 hp at the rear wheels.
In a thirdgen that would probably put you into the high-13s.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
