Difficulty of Rebuilding?
Old Sep 9, 2002 | 04:18 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I've never rebuilt a motor before. My current motor has 130k on it and is on its last leg. I want to buy a junkyard 350 or 400 over the winter and rebuild it as time/money allows. How hard is it to actually rebuild a motor? If I buy a book on it will I be ok?
Old Sep 9, 2002 | 05:09 PM
Morley's Avatar
Not hard if you measure everything, twice, and be sure of your clearances. It is expensive, however. Machine work costs an arm and a leg now a days, and you need to make sure to take the block to a GOOD machine shop, not Bob's cut rate butcher shop.
Old Sep 9, 2002 | 06:16 PM
Car: 1986 IROC-Z28
Well how can you tell a good machine shop from a bad one?
Old Sep 9, 2002 | 06:51 PM
Morley's Avatar
Ask around, and find out where local racers get their machine work done.
Old Sep 9, 2002 | 06:53 PM
RJR99SS's Avatar
word of mouth really....
I learned of my choice machine shop just from a mechanic at work, he's a high quality guy so i assumed he'd only accept a high quality place to do his machining, and i was right.
of course one thing to think of....
a machined junk yard block can be just a little less expensive than a brand new gm or aftermarket block. personally i always just shell out the money for a brand new block, at least that way you know exactly what you have...
Old Sep 9, 2002 | 06:58 PM
Car: 1986 IROC-Z28
How much are brand new blocks?
Old Sep 9, 2002 | 07:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming a 350 (because you don't want to spend any money on a new 305 block) - starting at about $1200, go to around $2000 for factory new shortblocks.
Actually, you don't really want to rebuild your 305, either. $'s/hp, it really isn't worth it. Actually, $'s/anything, it isn't worth it except for the experience. Even then, it makes more sense to find a builder 350 engine and re-do it.
Old Sep 9, 2002 | 07:19 PM
Car: 1986 IROC-Z28
I was considering buying a shorblock as then I wouldn't have to mess around with the bottom end. I was a bit intimidated by the crank/bearings. Do you know of any good places that sell rebuilt shortblocks?
Old Sep 9, 2002 | 07:22 PM
Morley's Avatar
Check here.
http://www.sdpc2000.com/cart.asp?act...tart&catid=514
Old Sep 9, 2002 | 07:29 PM
Car: 1986 IROC-Z28
The L98 shortblock doesn't sound too bad. I don't think I need a 4 bolt main seeing as I will only be putting out ~400hp. From what I've seen people have been getting decent power out of the L98's, would it matter any that I have carb and the L98 was a TPI motor?
Old Sep 10, 2002 | 08:05 AM
Car: 1986 IROC-Z28
Anyone???
Old Sep 10, 2002 | 08:28 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Carb or TPI, it doesn't matter, just get an intake that fits the heads. 400hp is no prob for a 2 bolt, as long as the max rpm isn't 7k.
Old Sep 10, 2002 | 08:40 AM
Car: 1986 IROC-Z28
Personally, I've never heard a story of someone F*cking up a 2 bolt main, If anyone has, let me know.
Old Sep 10, 2002 | 10:53 AM
Morley's Avatar
Only when super/turbocharging and using extreme amounts of boost.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
