L-82 ticking
Old Sep 9, 2002 | 09:29 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
L-82 ticking
i'm trouble shooting a 76 'vette that has a tickin' sound comming from the driver's side of the engine.
i heard of manifold's getting a bit loose and making that ticking sound but i'm not sure.. the engine "supposibly" got rebuilt last year up to '76 spec. (210hp and low 300 lbs tq?).
the sound didn't seem to be comming from the manifold tho, but as my car was, sounds are deciving from where they come from..
i'm just wondering what the most likelly possibilities are..
Old Sep 9, 2002 | 09:52 PM
rezinn's Avatar
At the manifold or collector probably. If the manifolds are original there could be a hole rusted through that would cause a ticking.
Old Sep 9, 2002 | 11:08 PM
Car: Formula
Engine: 400 sbc
thanks rezinn
Old Sep 10, 2002 | 12:04 PM
bradkeith's Avatar
Sounds like it could be a rocker arm out of adjustment also?
Old Sep 10, 2002 | 01:48 PM
iroc22's Avatar
One of my manifold studs broke in half and created a ticking sound. That could very well be your problem.
Old Sep 10, 2002 | 02:10 PM
84TAProject's Avatar
Definetly check the rocker arm, this seems to be a recurring problem on my TA, but 10 minutes later its back and good as ever.
Old Sep 10, 2002 | 11:04 PM
Car: Formula
Engine: 400 sbc
well.. i checked the manifold and flange that goes to the exhaust and they were ALL loose..
so i tightened them and started it up and it was still there so i undid the valve cover and checked all the rockers, the intake rocker on the driver side, 2nd piston was knocking.. but there's a lifter down there ticking slightly.. i think it's just crap stuck in there.
a better oil in that motor would help too.. whew.. if i had any gallons laying around i'd do an oil change to something better..
anyways. i go for a ride and the ticking's back.. not as loud as before.. but still there..
wtf?
whatever.. i'll tell him to get that thing tuned up cuz i seriouslly needs it.
(i think it's never been opened up since the mid seventies.. )
in any case, thank you all who responded.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
