Rebuild vs. crate
Old Sep 15, 2002 | 11:27 AM
silverbullet's Avatar
Rebuild vs. crate
Which is more cost effective rebuilding a 350 with new every thing heads, headers, gaskets, pistons, etc. Or just droping a crate into it. Keep in mind I want it to pass inspection in VA and I will be doing all the work by my self and some help from a few of my buddies. If I do rebuild what sould I do? New heads, camshafts, please tell me what I should do. I want the car to have around 300-350 rwhp. I also really don't what to run Nitros Oxide. Just because I have heard some pretty brutal stories. Is that possible on a $2000 budget. And do you think it would be possible for a couple of 18 year olds to rebuild an engine in a few days during the summer?
Thanks a lot
Old Sep 15, 2002 | 02:36 PM
silentmisfit's Avatar
I wouldnt say a few days.youn can get a short block crate motor in your price range add a few uprdes and have the power your looking for.If you rebuild you have to at least hone the block for new rings and ive seen rebuilds kits as low as 299.00.figure in the heads and everything plus time to it.a crate motor can get you going quicker.
Old Sep 15, 2002 | 02:47 PM
ronterry's Avatar
Car: '94 Corvette
Don't forget about the warrantee you get with crate motors.
Build it youself if you want tight tolerances, & custom bottom end parts. I hope you have a little experience cause theres no warrantee this way.
Good Luck,
Ron
RedLeader289
May 28, 2019 01:47 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
