Can a LG4 intank fuel pump support a TBI motor
Old Sep 16, 2002 | 07:59 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I have a 87 Camaro that came from the factory with a LG4 motor that used an electric fuel pump. When I got the car the LG4 was gone and a 350 carbed motor was in its place. The in tank pump wasn't being used only a mechanical pump. Now I am running a TBI setup and I am wondering if the LG4 in tank pump will support the TBI motor? The reason I ask is becasue I believe I read somewhere that the LG4 carbed motors used both a in tank electic and a mechanical pump, which leads me to the question of how much pressure the intank LG4 pump puts out. Any input would be appreciated.
Old Sep 16, 2002 | 08:06 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
as far as i know, the LG4 has 1 fuel pump and its mechanical. passenger side by the AIR pump....
ps. why go from carb to TBI????
Old Sep 16, 2002 | 08:55 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
no it can not
that pump puts out about 5-7 PSI
TBI REQUIRES 13-15PSI
oh yeah, i'd stay with a carb too
Old Sep 16, 2002 | 09:54 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
keep the carb! TBI in my opinion sucks, TPI looks good and peforms very well with light mods but, falls short in the big HP numbers so if you got carb keep it
Old Sep 16, 2002 | 11:12 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
I have the LG-4 in my Z28 & have replaced the fuel pump on the right front part of the motor. I was not aware that there was anything like a pump in the tank except in the TBI & TPI cars!
Old Sep 17, 2002 | 04:30 AM
Car: 1992 Camaro
Engine: 350 miniram
Ok I should explain a little more. That 350 carbed motor that was in my car is actually a ZZ4. It came out and now has a miniram which will be going into my 1992 RS which had a 305 TBI from the factory. The TBI motor from the RS is going into the 87 Camaro I have. That is the reason that I am using TBI becasue I have the complete motor, sensors and all dropped into the car already. It would be way to much work to take that stuff off and install a carb which I don't even have.
So back to my problem. If that pump isn't going to put out enough PSI to run this TBI motor than will I have to add a mechanical pump to the block? Will having the 2 pumps like the LG4 did increase the PSI to let the TBI run correctly? I could always drop the tank (what a pain) and put a TBI pump in, but I would rather install a mechanical one to help the in tank if I can.
What do you guys think?
Old Sep 17, 2002 | 01:23 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
No...I had an 84 Firebird V8 with LG4 engine...after searching around I found that the the L-69 engine of that year had a helper electrical pump simply to help overcome vapor lock issues of a carbed engine.
You need to use an in-tank TBI pump...simply put...to accomplish your goal.
Your Miniram motor in the 92 certainly needs more than a TBI fuel pump to make it work....so use that...
And yes, it will be a huge PITA no matter what option you want. To use the TBI setup, you need a TBI fuel pump and one that is in the right range as well. If you put in a pump with a MUCH higher capacity, then you will need an AFPR to get it back to the 14 psi you need.
HTH,
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
