Need help with block removal
Car: Corvette
Engine: 5.7
im trying to remove my engine that is seized up. all i have left to do is disconnect the motor from tranny and then lift it out. but i cant get to the last bolt for the flywheel/torque converter. so how do i go about this?
Originally posted by RB83L69
It's not... it just pulls out
The TC hub has a spline that mates to the input shaft of the transmission, plus an outer shaft that drives the oil pump in the trans. You'll see when you get it apart, and reassembly is very straightforward.
C409
Jan 21, 2016 08:29 PM
gixxer92
Sep 1, 2015 04:32 PM
