How much lift can l98 springs take?
Old Sep 22, 2002 | 11:31 AM
TBI305Camaro's Avatar
When I did my valve seals I replaced my springs with a set of l98 springs. How much lift could I go with them?
Old Sep 22, 2002 | 11:37 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
I was at the limit with a SLP 51006 .495/.502 lift camshaft so I changed them. Coil bind wasn't as close, but pretty close, as the valve seal were. Didn't run it that was so I couldn't say if it would have worked or not.
Old Sep 22, 2002 | 01:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are the same garbage you had before. I hope you didn't pay money for them.
Anything more aggressive than a worn-out stock cam with rubber rocker arms is too much for them. So I'd say about .425" is as far as you'd want to push it with a stock profile, somewhat less than .400" with an aftermarket grind.
Old Sep 22, 2002 | 02:53 PM
Damon's Avatar
Stock springs can take about .500" lift without binding but that's not the full story. They don't have enough pressure to control a hotter-than-stock cam. Also, you will smack the retainers against the guide seals long before you coil bind the springs (about .470" on most stock heads). While a fresh set of springs is better than ages-old OEM springs, it's not what you want if you have installed a performance (non-stock) cam.
I've disassembled about a bezillion sets of stock heads and they almost ALL have the same springs- 65 lbs. seat presure at an installed height of about 1.75". L-98, TBI 305, emissions-era V8s, etc, etc. You name it. That's what the vast majority of them got, with rare exceptions. For even a modest performance hydraulic cam you want something on the order of ~100 lbs seat pressure to keep the valves well controlled at higher RPMs.
Old Sep 22, 2002 | 03:24 PM
I was maybe planning a lt1 cam before I get new heads but Im not sure yet. Could those springs take the lift of a lt1 cam? I also plan on a set of world S/R torquer heads which can take a .560 lift. While i was doing the seals i just wanted to get some new springs in there. I paid 20 bucks for the set...
Old Sep 23, 2002 | 09:06 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
keep in mind you'll need to get your valve guides milled and get screwed in studs put in if you go with a higher lift cam, might not need to with a stock lt1 cam but i'm not sure on its specs
Old Sep 23, 2002 | 09:32 AM
I cant remember the exact specs of the lt1 cam either but Im pretty sure its less than .480 both ways.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
sandman92084
Sep 12, 2015 10:27 PM
