Swaping Balancers
Old Sep 23, 2002 | 12:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Swaping Balancers
I have a 350 with an 8" balancer, can i swap my smaller 305 balancer without any trouble? Do i have to have it balanced or will i be fine?
Old Sep 23, 2002 | 12:45 PM
Damon's Avatar
It will fit and work but the timing mark probably won't line up. The mark on most 305 balancers is at 12 o'clock (straight up, viewed from above and behind water pump) while a 350 is usually at about the 1:30 position, off to the side of the water pump.
Old Sep 23, 2002 | 02:18 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
So if i just use the timing tab from the 305 cover it should be fine?
Old Sep 23, 2002 | 02:24 PM
Damon's Avatar
Yes, you should be OK doing that. Just make sure that you don't need to do that first. Take off the balancer and line up the keyways where they reference to the crank and see if the timing lines points in the same direction on both. If they do, you don't need to mess with the timing tab at all. The timing tab is usually tack-welded to the timing cover on most stock covers, so you would have to swap the entire timing chain cover- a lot more work if the engine's still in the car (drop oil pan, undo engine mounts, etc, etc.).
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
Magman
Sep 13, 2015 12:14 AM
john204481
Sep 7, 2015 03:22 PM
