What rear end gear size do I have?
Old Sep 27, 2002 | 01:19 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I have a 1991 Camaro RS 305 V8 TBI. What size gears do I have in the rear end? I want to put in 3.73 gears, and I'm confused with measurements and stuff (inches diameters stuff like that) Someone help meh!
Old Sep 27, 2002 | 04:11 AM
ede's Avatar
ede
7 1/2 or 7 5/8 ten bolt, gm wanted to confuse everyone by calling it 2 differant things when it's the same. for the ratio pull the cover and count teeth or find it stamped on the ring gear and do the math.
Old Sep 28, 2002 | 06:09 AM
Vader's Avatar
Or if you're lucky you can find the stamped data on the right axle tube and decode that for ratio, lockup, and gear sizes. Sometimes they aren't all rusted over so they can still be legible.
Old Sep 28, 2002 | 08:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Like ede said, it's the 7.whatever 10-bolt. If the rear is the original one for the car, and if it still has the original gears in it (neither of which is a sure thing), it's probably either a 2.73 if it's an auto or 3.08 if it's a 5-speed.
In both cases, it's the 2-series carrier, so 3-series gears won't bolt onto it unless you either use the special thick gear set (dumb IMHO) or a spacer. But, since your car is a 91, if the rear is still the original one, it has 28-spline axles, so the $100 posi from SLP will bolt right in. My recommendation would be to get one of those and the gears you want, then it will all just go together right.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
