Question about this Cam I Bought
Old Oct 3, 2002 | 10:16 PM
zerotosixtyV8's Avatar
Car: Camaro
I sorta jumped on this one cause it was a good deal, but I bought a Lunati cam grind #00012. It is supposed to be an ideal mild cam. Is it good for an 89 L98?
Old Oct 3, 2002 | 10:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is it the same for the part #? Cause here are the specs. 300*/300* adv duration. .515/.515 and a powerband of 2500-6500 rpms, which I don't think would be a good match for TPI induction, but I'm not expert. They don't breathe well in upper rpms which that cam needs, and seems like gears and a higher stall TC are needed too.
But that's just my guess at it.
Old Oct 3, 2002 | 10:35 PM
Car: Camaro
those are the specs. I plan on improving breathing through exhaust, heads, rockers, pushrods, lifters, throttlebody etc. for it. as well as a torque converter. I'd like it to be able to run up to 5700 rpm, which it appears this cam would allow. so it'll be nice.
Old Oct 3, 2002 | 10:50 PM
Car: 99 Formula
Axle/Gears: 342
Stock TPIs stop breathing past 4500 rpms, you can do some things to up it a little, but I'm sure you can forget 5700 rpms, that's why you'll see a lot of guys get an LT1 intake or Stealthram, stuff like that.
Old Oct 3, 2002 | 10:54 PM
Car: Camaro
I want to get an LT1 intake when I get some more money. It's all in stages really.
Old Oct 3, 2002 | 11:02 PM
Car: Camaro
the other cam I could've gotten was an LT4 motor cam, would this have been better?
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Sep 7, 2015 01:37 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
