my 400 would probably run better if I was getting more than 7degrees mech advance
Old Oct 16, 2002 | 07:46 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
... oh mallory strikes again.
Two comp 9000s i have seen had advance weights that hang right at a point on the inside radius of the distributor shaft lobe.. (it matches up right to the arc on the outside of the weight)
Old Oct 16, 2002 | 07:59 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
MSD...just an opinion though..I could be wrong:lala:
Old Oct 16, 2002 | 08:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That might impact performance a bit...
Is this part of the post mortem from your dyno run?
Let us know what its next pull is, after you get all that stuff sorted out, I'm hoping to see some 400-425 RWHP numbers.
Old Oct 17, 2002 | 07:19 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
yeah..just getting enough time to check over everything now.
I figure i will go over everything again and make sure there is not anything obvious. If I still cant find the hidden hp.. I am going to pull it out and put it on a engine dyno. I have a spare carb, intake and cam to troubleshoot with on a dyno.
Old Oct 17, 2002 | 06:00 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
amazing what a little timing will do..
I think the dork that worked on the distributor last (me), set the limit wrong. Now it pins you back in the seat good. Second gear just starts the tires frying.
Probably picked up 15percent more hp at the tires easy.. time for more tuning.
we have found the enemy and they are us.!!!
I should get a big anvil and put it on the hood so I will have to find someone to help me lift it off b4 i go working on it again. Nows about the time I probably start breaking drivetrain parts.
Old Oct 17, 2002 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So many of us have a similar dork working on our cars...
BlackphantomZ28
Apr 24, 2016 08:14 AM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
armybyrd
Aug 10, 2015 09:23 PM
