400 Cid Sbc
Old Oct 17, 2002 | 07:39 PM
widow_maker89's Avatar
400 Cid Sbc
will heads off of an 89 Trans Am L98 bolt on to a 400 sbc? second wil that have any issues going into the 89?
Old Oct 17, 2002 | 08:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They'll bolt on but they should have steam holes drilled in them first. You might want to check what the compression ratio will be too.
Old Oct 18, 2002 | 12:48 PM
bttt Furthermore, does that mean i would have to use a flat tappet cam?
Old Oct 18, 2002 | 02:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have to use a flat tappet cam, but you can't use factory roller lifters. You may also need a small base circle cam.
Other issues include externally balanced harmonic damper and externally balanced flexplate (typically 168 tooth, which is 14", often causes starter issues requiring the use of a ministarter).
Going with the L98 heads is the right move. Factory 400 heads are boat anchors. Drill the steam holes using a 400 head gasket as the template.
Old Oct 19, 2002 | 09:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Originally posted by five7kid
Factory 400 heads are boat anchors.[/B]
I can vouch for that. I can't wait to get new heads.
armybyrd
Sep 28, 2023 12:16 AM
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
