Can I use An Elec. Fuel Pump on our cars???
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Is it possible for me to use a holley/carter/ any aftermarket elecric fuel pump on my car??? What do I do with the return line???? I need a new pump, I figure I might as well go electric and get the Holley one that doesn't need a regulator.
I know it's not safe to cap the return line and I do not want to remove it because I may need it later.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm running a holley blue fuel pump. I have heard that these things die within short amounts of time but i haven't driven my car for more than 30 minutes straight due to some problems .....but i have heard some people kill them right away and some last a LONG time. I guess it really matters on whether it's a daily driver or not. I have heard that the carter pumps were made for continuous use and could feasibly be used for a daily driver....good luck
Steve
Steve
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the problem I tend to have is the pump will loose prime
I have to put a garden hose on the end and start a siphon if it sits for more than a couple of days. The pump needs to sit below the tank sump and thats pretty difficult to find a mounting point that low on a 3rd gen.
Note about electric pump noise....
....I searched around for this info can couldn't find it, so I wanted to post my experience...
The Holley Blue pump is LOUD. I mounted mine to the wall behind the driver side rear seat, and didn't have problems with fuel supply, but the pump was very loud. I replaced the inside-the-tank pump with a straight tube, and let the blue pump pull through that. It worked fine.
I did as much research as I could, and finally took a chance and bought a Mallory Comp 110 pump. I'm happy to report that it is about a thousand times quieter. Seriously, it's a lot quieter.
The blue pump never failed, and in fact I'm still using it for a nitrous pump. I cannot comment on the durability of the Mallory as yet, because it simply hasn't been installed that long yet.
RSR
RSR
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
