Why does my heater make my rpms surge?
Old Oct 23, 2002 | 07:23 PM
flotsamm's Avatar
If I turn on my heater, the rpms surge up and down. When its surging, the AC compressor is cycling on and off every few seconds(needs a re-charge). But why would the AC compressor even need to turn on when I'm using my heater?
Any help is greatl appreciated. Thank you.
Old Oct 23, 2002 | 08:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The defroster cycles the ac on and off its just the way they make them. I dunno maybe someone can explain why. I personally just unplug the ac pressure switch when it gets cold. Dont need anymore cold air.
Old Oct 24, 2002 | 08:26 AM
flotsamm's Avatar
Ahh thanks. About that pressure switch, where is that located? Thanks for the reply.
Old Oct 24, 2002 | 08:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The reason they do that is because it makes the defroster work so much better. Most of the actual work that the A/C system does consists of emoving humidity, not cooling the air; so running the compressor multiplies the effectiveness of the defroster by supplying dry air instead of moist air.
If your A/C cycles when you use it, put some Freon in it. You'll find that your defroster will clear your windshield in a small fraction of the time it takes without it.
The compressor is called for when in defrost mode, but not in heat mode however.
TheExaminer
Aug 26, 2015 04:59 PM
jbd1969
Aug 17, 2015 07:06 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
