Question about my fan after TBI--->carb swap
Old Oct 26, 2002 | 12:22 AM
TBI305Camaro's Avatar
Will I still be able to run my hypertech fan switch? If not why not? the ECM will still be hooked up just missing alot of stuff..
Old Oct 26, 2002 | 09:35 AM
Vader's Avatar
As long as you still have electric fans and a separate control for them, there's no reason it shouldn't work.
Old Oct 26, 2002 | 10:59 AM
what do you mean by separate controls???
Old Oct 26, 2002 | 11:17 PM
ttt
Old Oct 27, 2002 | 12:26 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
isnt the fan turned on once the switch hits a certian temp? So it should work even w/o a computer. Cause the power is hooked straight up to the battery and the negative is hooked up to the fan switch correct?
Old Oct 27, 2002 | 07:23 AM
alright i guess ill go ahead and try and see if it kicks on or not after i get the motor in. I really dont wanna have to run a fan switch again.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
