Cats
Old Oct 30, 2002 | 05:06 PM
Adam62083's Avatar
Cats
Mine are rattling pretty bad. What kind of adverse effects can this have other than being bothersome? Could it give faulty O2 readings?
Old Oct 30, 2002 | 05:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Usually means, it's going bad, and may clog up soon. I'd replace it with a hi flo one.
Old Oct 30, 2002 | 05:29 PM
Adam62083's Avatar
I just want to know if its what is causing my idle problems.
I have cleaned the IAC, I have checked the TPS, everything should be fine.
Except my idle is a little erratic, dips low sometimes and makes the car shake before it surges back up, and sometimes dies when going into gear.
Also I get an intermittent code 43.
Argh.
Old Oct 30, 2002 | 05:36 PM
Car: 99 Formula
Axle/Gears: 342
Argh.
One time my GFs 96 Blazer's idle would dip a little low when coming to a stop, I guess if it got worse may have stalled. Tookk it to a dealer and it was a bad cat.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
