no heat?
Old Oct 30, 2002 | 10:25 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
no heat?
ok I seached but I cant find the answer. I just lost it dont know what happened. is there a vacum hose or somthing I pulled off by accident? thnks brr its cold. snowing even.
Old Oct 31, 2002 | 02:56 AM
1a12's Avatar
i am not sure, but here are a few things i know about....There is (i think) a ported Vacuum switch in the intake manifold, Not sure if that has anything to do with it. There is also a possible stuck thermostat. or a clog in the heater core. Also a possibility of the heater control switch to switch from hot to cold could be bad.
Just some places to start. Hope it helps.
Old Oct 31, 2002 | 06:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check the vacuum line going to the heater control valve, if your car has one - different models & years vary.
Snow sucks...why did I move here? I'm an idiot I guess.
Old Oct 31, 2002 | 06:31 AM
SHAGME's Avatar
Car: 1988 IROC-Z
ok cool thnks guys Ill have a look
Old Oct 31, 2002 | 08:59 AM
Vader's Avatar
I'm not positive (never really am) but I think '87 was the last year without the hot water control valve - or maybe it was the first year with it. I know the '86 doesn't have it.
Do you get any air flow at all? Can you change the air delivery from the defrosters to the vents to the floor outlets, etc?
It's been a little cool here, too. I haven't quite finished setting up the new area yet, so it was even cooler than I liked in the garage. At least it was until yesterday afternoon:
Old Oct 31, 2002 | 10:05 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My 89 Iroc has a hot water control valve.
Old Oct 31, 2002 | 02:41 PM
ohohblita's Avatar
i believe 87 was first year.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
